97 is throttle body fuel injected. And distributor. 98 and up used port injection. Because of this you will need engine harness and PCM off of a 98 and up car. no distributor on these so you will need the coil packs too.
_________________ Fainya 97 Geo Metro LSI,1.3L-GT-DOHC-16v,4.10 5-speed,A/C,170,000,suspension lowered 1",4 wheel disk brakes,15"alloy wheels with 185/50-15 Toyo's,GT bucket seats,analog oil pressure gauge,cruise control, new paint job. 40 mpg at 65 mph. Good, fast, cheap. You only get two.
