hotrodray1 wrote:
I did this in a 89 swift but changed the cam and intake to the tbi one on a swift. Almost every thing bolt up. Where I had my trouble was where the stub axle for the 1.3 swift bolts to the block in the rear. all the holes were not there only 1 of the boltholes was there so I made a bracket to hold it in place.
Sounds like it'd be ideal to use the original block with a Samurai head. But making a bracket isn't the end of the world. So you used a Sammy block and head, but Swift cam, intake, and tbi?
geopat wrote:
The samurai intake will only fit the 8valve cylinder heads. probably be the easiest to find a 8valve 1.3 motor out of a mk2/3/4 car.
The car in question actually has a bad head gasket which I was about to replace. If I can track down an 8-valve 1.3 head, will it bolt right up?
