GeoZukiGTi wrote:
Let me know what it's like when 18 lead acid batteries spray all over when you get rear-ended.
better than gas! battery acid is really 'not that bad' and if washed off you would likely not be injured. The batteries in the back (under rear seat) are enclosed in a steel rack, which is lined with polypro plastic.... and the ones in the front are isolated from cabin by normal firewall. In either case the injury from impact wold be far more intense than battery acid, and far safer than gasoline.
GeoZukiGTi wrote:
Also, electric isn't clean. It takes coal or nuclear energy to make that power.
or solar.... even if it is 'dirty coal', the emissions are less than individual cars. BUT I absolutely agree that more power plants are not what we want, which is why I also installed enough PV to produce my own power for my house AND the car.
GeoZukiGTi wrote:
And for $8k, I can buy a mint Geo Metro convertible, and feed it with gas for 5 years.
and my electric car will run another 10 or 15 years with NO maint. costs except brake pads, NO fuel cost (since I produce my own), and NO greenhouse emissions. I'll have to put in another set of batteries for about $1500 (not $4000).
GeoZukiGTi wrote:
GM's Volt is a far more practical car. For 40k, it's expensive, but it works in Michigan, where the winters are below 0f, and the 8 hours of daylight we have in the winter, it's overcast(no solar).
The volt is expensive because they chose to go with AC motor and Li batteries... My point is that we COULD have electric cars that are as practical retailing for $15K if they went DC and Lead batteries for the 'entry level' cars. Cold winters are still fine for electric cars, you just divert a little of the juice to battery warmers and insulate the battery boxes. Solar production in MI may not make sense, but what about wind, biomass, algea-oil, etc.....
My main point in doing this is simply to prove that an inexpensive electric car with 40-50 mile range IS practical for MANY homes, not all....
Dan
'97 Swift, converted to Electric -
www.envirokarma.org
