Current car setup:
- 3-Tech +10 cam sprocket
- 10 deg ignition advance
- 3-Tech underdrive pulley
3-Tech 350/220 cam
- 92 octane fuel
- removed fender airbox and tubing
- removed TBI aircleaner bridge
- 175/70R13
Powerband does broaden, both low and high rpms. Throttle response has improved. The little N/A 1.0 wants to sing to redline and probably beyond. Idles rough and occasionally hunts between 800 and 1000 rpm, but hasn't stalled yet. I'll advance the timing more to see if it helps. Exhaust note has deepened like Aaron said.
Once again 3-Tech delivers another quality piece for the humble little 3 cylinder. With this cam I believe I can now accelerate to keep people from cutting me off just so they don't get stuck behind this "slow" metro.
I'd buy it again if I had another car to put it in.
EDIT 10-13-05: Lost between 6 and 8 mpg. Experimented with the TPS and the idle adjustment screw. Not idling as rich or hunting like before.
I think I am having alternator problems though so the idle is also a little high at 1100. Once thats replaced I'll try get it back down to 800.
Edit, Edit: Not alternator. I'm pretty sure it was the heavyweight oil I was using (20w-50 doh). Using 10w30 and everything is alright. Idle down to 900.
