Found in the threads of my cam and crank timing sprocket bolts.
Loctite? They were stuck on pretty good
Could this stuff really just be corrosion? This is probably not a Swift-specific issue. Who has done a thousand timing belts and has seen this before? What's a better solution instead? I am pissed I had to work this hard to break these loose, but they don't appear to be otherwise damaged. I am tempted by the experience to go to the opposite extreme and use anti-seize when I reassemble, but something tells me that's not the answer. Maybe a good clean up using WD-40 or similar instead?
