Since you have a 2000 Swift manual transmission car, its engine is a G13BB SOHC 16V engine instead of the G10 3 cylinder that uses unequal length CV axles.
This also means that your car uses an intermediate shaft bolted to the engine block, so that the (right) passenger side CV axle is almost the same length as the driver side CV axle.
The intermediate shaft itself is no longer available, but the bearings should be serviceable/replaceable. (contact teamswift member bbowens if you need parts) If your intermediate shaft is in good condition, go back to the parts store and get them to look up the correct CV axle for your year/engine/transmission combination. Your new axle will simply slide into the intermediate shaft housing; you can then reinstall the whole assembly back onto the car.
