Sorry to get back to you so late on this--I'm sure you've figured out some sort of fix by now. But what I'd do in your situation next time is:
1) Never count on RTV for fixing any sort of leak, particularly a wrong O-ring kind of leak 2) Doublecheck the pipe itself because they often rust all to hell at the water pump connection and the only fix there is a new one, unless you are one hell of a sheet metal welder and grinder. 3) Easiest fix here is to order up a new water pump from our favorite cheap auto parts supplier, RockAuto, for less than $15, and use the O-rings that come with that pump, and keep the water pump on the shelf for a spare.
Live and learn, live and learn.
Best--Dan White
