Do not use eristic brand or DNJ brands. Both have been unreliable in my experience. Name brand gaskets are not terribly expensive and are worth the extra $$$'s. Fel pro from rockauto.com is a cost effective option. You need to order a head set and what's called a conversion set that has the bottom half engine gaskets. I have used one or two engine tech sets over the years and think they did ok. When I speak of dnj&eritistic, I had multiple failures on each brand, when properly and professionally installed, on different engines(1.3 Suzuki, 1.5&1.6L, 3.5L Hondas). This leads me to believe they are pretty risky to use. To many failures to call it bad luck.
_________________ 1995 Swift w/16V 4.39s, 3tech cam, Esteem t-body, Header, needs more. 1995 Gt Mustang "Boss Shinoda" package. 1999 F150 4x4 Supercharged 1967 Mustang 428 auto, never ending expensive project 1993 Civic si h22a, fell in my lap, couldn't resist!
