It is currently Sat Nov 25, 2017 12:01 am
PostPosted: Mon Jan 06, 2014 12:25 pm
If you still have the factory radio in your car, chances are it is tired or broken. There is nothing wrong with the factory radio, but it leaves much to be desired.
1. Here is the stock Radio
2. Pull out the ash tray to remove 2 screws
3. Then remove 2 screws on top
4. Pull the bezel out and pop off the cigarette lighter
5. Remove the 4 screws that hold in the radio
6. Remove the hidden screw underneath the radio, behind the ash tray.
7. Reach behind the radio and pull out the clip and the antenna
8. Now you are ready to measure and install a new radio! A standard size single or double DIN radio will work. The depth is greater than 7"
