It is currently Sat Nov 25, 2017 12:05 am
PostPosted: Sat Aug 31, 2013 3:04 pm
I just purchased a 93 swift that won't start the car had a factory alarm which was half removed by the previous owner. No gas no spark is there any way to bypass the whole alarm ? I read another post where they closed off wires to the alarm but in my case the alarm is out of the car now its a mess.
When I turn the key no red dash lights come one the fuel pump doesn't come on no beeping sound but the car turns over. Also headlights don't work tried looking for the alarm fuse no luck disconnected the wire that splays into ignition switch from steering colum I've changed fuse box, relays in eng compt no luck.
I did find the alarm box under driver side of dash it clicks when I turn the key on and off
Thanks
PostPosted: Sat Aug 31, 2013 3:23 pm
acedoggy wrote:
I just purchased a 93 swift that won't start the car had a factory alarm which was half removed by the previous owner. No gas no spark is there any way to bypass the whole alarm ? I read another post where they closed off wires to the alarm but in my case the alarm is out of the car now its a mess. Thanks
Take the alarm-fuses out, that's what I do all the time...
image_id: 22616
1993 Swift Gti
PostPosted: Sat Aug 31, 2013 3:45 pm
by the fusebox there is a thicker wire, its either black with a red stripe or black with a yellow stripe, it has some weird splice in connector, you have to remove that connector.
08 Civic Wife's car
