It is currently Sat Nov 25, 2017 12:08 am
 Post subject: cam etc lube
PostPosted: Thu Sep 27, 2012 10:00 am
I usually have a rebuild waiting to be used, after sitting a while the oil seeps away from where you need it.
After rebuilding my little OHC engines I leave the valve cover loose.
Seconds before starting engine for the first time I pour oil all over the cam from end to end.
SCIENCE IS A WAY OF THINKING...Carl Sagan
 Post subject: Re: cam etc lube
PostPosted: Sun Jul 07, 2013 7:41 pm
Great idea, depending on how long an engine will be sitting i usually use red assemly oil when i do a head job, its very thick and will keep lubed (for a decent amount of time)
