It is currently Sat Nov 25, 2017 12:40 am
 Post subject: Piston wrist-pin removal
PostPosted: Tue Feb 21, 2012 1:55 pm
Piston Wrist-Pin removal,
I’m just wondering what others might use to press the wrist pins out/in on the piston connecting rods on the 1.0L.
During a recent top end upgrade on my daily driver (head replacement due to a cracked head) I decided to go ahead and put in new pistons, which I should have done back when I did a total rebuild. Oh well, we all learn from mistakes. After close examination and advice of the FSM, I found out real fast that removing and reinstalling wrist pins is no cake walk. Luckily I do own a 20ton press, but then there was the issue of holding the piston steady in order to remove and reinstall. The FSM shows a picture of a fancy tool that probably not a one of us would own, or know where to obtain
After some trial and error, I finally sat back and fabbed up the following. It would be better done with ¼” tube steel, but what I used was all I had. What I used was 2” tube steel, ¼” angle on which the piston flats rest on, and a piece of ¾” pipe. The pipe acts as both a catch basin for the pin, but mostly as a support for the thin tube steel I had.
Mike
Valley Grande, AL
1986 Sprint plus
Do you maintain a personal fleet like I do?
Why do we do it?
Because it's what we enjoy and because we CAN.
2011 camaro, 2005 Vibe, 2016 Outback, 06 Expedition, 87 Porsche 911, 87 Turbo sprint, 82 Brat, 73 gmc 4x4, 69 camaro, 99 Gl1500 Honda Goldwing, 12 Kawasaki klr650, 2012 Kubota L3200, and we wont even go into the small stuff.
Users browsing this forum: Bing [Bot] and 3 guests
