ansariatteamswift wrote:
Hi Phil,
Will item #150577912384 of carsparesdirect ebay shop suit for window winder showed on my attachment?.when i contacted company-carsparesdirect, replied that it was no longer available.Please suggest more.
Here are two 'universal' electric motors for $138
Item: 370450083238
These are not exact replacements; but you can contact the company and inform them of your year make and model.
Perhaps they have something which is correct.
If you are in a tight budget, you can use a Dorman
Item number: 370474183858
and a pair, which cost less than $46 shipped in the USA
Item number: 180678485185
Notice that there is no difference between the right and left.
From time to time, universal electric conversion kits are available on Ebay, so monitor the site for several months to obtain your best value.
Make sure to post pictures of your vehicle if you are going to be needing detailed help from the membership here on Teamswift. Hope this helps and welcome.
DIY Broken Bolt Removal:
viewtopic.php?f=22&t=41042DIY Clutch Adjustment:
viewtopic.php?f=9&t=48281DIY Wheel Bearings:
viewtopic.php?f=2&t=29003DIY Shocks:
viewtopic.php?f=10&t=45483DIY Wheel Align:
viewtopic.php?f=2&t=42479Once you get the cars dialed-in (compression, leaks, bearings, alignment, brakes) swap in new rubber and glass, you've got something which should last for years!
