It is currently Sat Nov 25, 2017 1:25 am
PostPosted: Fri Sep 17, 2010 3:57 pm
Hello m[youtube][album][/album][/youtube]y problem is that on my 1992 suzuki swift hatchback the driverside rear wheel bearing has been welded onto the spindle. I have put a torch to it and pryed on it and it will not come off. I am thinking that it may be just as well to replace the entire spindle assembly. Providing that is the right terminalogy for that part. please can you help me figure out the best way to fix this problem and maybe help me in finding the parts. Thanx JJ.[album][/album]
PostPosted: Fri Sep 17, 2010 9:54 pm
I had the same problem. Look in my album and you'll see that I had to use a dremel and cut it off. Not to hard just be careful and try not to nick the spindle. Nice thing is that the parts are easy to come by if you to need to replace both the spindle and the bearings.
