It's not a GM product, so the pins are different, look under the hood the jumper pins should be listed on the sticker.
You will either have a six pin of a four pin block. There is also plugging a fuse into the fuse block.
J. McBean: '98 Suzuki Swift 1.3L 16v SOHC 5sp+ "Mk5"
Made in CanadaThe Mini Rattler: '94 Suzuki Swift .993L 6v SOHC 5sp+ "Mk3"
Made in Canada *The Winter Beater*B. Berry: '90 Chevrolet Turbo Sprint 1.0L 6v SOHC 5sp+ "Mk2"
Made in JapanI got 18MPG in a 3cyl with a 5 speed manual 4dr, '93
Metro!
