1)MOTOR WAS RE-BUILT AT A REPUTABLE MACHINE SHOP(SHORT BLOCK) GUY WORKING ON MOTOR IS A TURBO GURU.
2)ALL NEW RINGS.BEARINGS.CYLINDERS HONED.NO OUT OF TAPER/ROUND.
3)NO DECK WARPAGE.5 THOU REMOVED FROM BLOCK/DECK TO ENSURE A PERFECT SEAL.
4)NO OIL/ANTIFREEZE MIXING TAKING PLACE (AGAIN,PERFECT SEAL)
5)MOTOR STILL SMOKED EVEN AFTER REMOVING TURBO COMPLETLY FROM ENGINE.
6)THE ONLY PART I MODIFIED ON THIS BUILD WAS THE HEAD GASKET.
i know the guy who did my work for me,i trust his work.I got all the old parts back,he was surprised that there was not much wear on all the internals for a motor that had almost 250,000+kms on it(main reason for re-build was blown h-gasket,too much boost,bad turbo/wastegate.
we both are stumped as to why opening the holes would make that much of a difference;but in his re-building database for 1.0 88-92 it refers to 'smoky engines after rebuild',points out that the small holes in h/gasket RESTRICT the flow of crank-case blow-by,some h/gaskets by different manufactures have larger holes,too much blow-by or internal pressure causes them to smoke.
BUT if that was the case why not push oil back up the oil returns at the front of motor with proper gaket installed?dont know.
ALL I DID WAS OPEN UP THE HEAD GASKET,AND IT SMOKED LIKE CRAZY,THE ONLY MOD I DID TO THIS MOTOR.
took another 1.0 turbo apart for fun,it has SMALL holes in h/gasket,my next one will be put togethor that same way(small holes)
sorry about the novel,i'm now back at work,4 months behind,30+vehicles to inspect 4 safetys,2 week window
