It is currently Sat Nov 25, 2017 1:49 am
PostPosted: Sat Dec 12, 2009 12:29 am
I have a headlight problem with my 1998 suzuki swift.
I am having issues with the daytime running light circuit. I first thought that the low beams went out in my car so I replaced the bulbs. my daytime lights still did not come on. Then the low beam lights stopped working. So i replaced the bulbs again. Now the low beams and the daytime lights do not work. I only have high beam light function and it only seams as if half of the bulbs are working, not as bright as they should be. I tried to trace the problem with my chiltons manual scematic and it shows a daytime running light module. I cant find this in any part store and before I replace this, I respectfully ask anyone if they have an idea about this before i spend a whole bunch of money.
I cant pass my texas state inspection until this is resolved. Can anyone help? Please?
PostPosted: Sat Dec 12, 2009 2:45 am
the headlights are on a switched ground circuit. there is an open somewhere on one of the grounds from the lights to the fusebox, check that first. anything else someone else can answer.
PostPosted: Sat Dec 12, 2009 7:51 am
Are the bulbs burned out? They will do that if you touch them while instahling them. Ex witch thought our old Caravan had a wiring problem after her man-child husband replaced passenger side 4 times!
36 time NHRA/IHRA Champion
05 SRT4 / 12.79 @ 111 mph / 40.1 mpg!
01 Voyager V6 / no mods yet / 24 mpg
84 Horizon / 1760 lbs / was 17.9, now 23.0 mpg
96 Geo Metro / 1590 lbs / was 46.2, now 60 mpg!
95 Neon / unk mpg so far
PostPosted: Mon Dec 21, 2009 7:20 pm
I have similar problems with my headlights too. In fact, that's why I google'd this forum.
My low beams and high beams don't work except the high beam will work when I keep my hand pulling the high beam flasher.
I checked my fuses and the ones under the dash are fine. I went into the fusebox in the engine compartment and found that the 30A PTC (for early fuel evaporation) fuse was blown, so I replaced it. It blows again.
I checked the wiring at the fusebox under the and saw that one wire has turned brown. I pull out the connector and find that it's pretty much fried. I'm told this is a common problem, so check yours. It's the white and black wire in the corner closest to the left wheel in your fusebox under your dash.
