It is currently Sat Nov 25, 2017 12:17 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jun 06, 2004 2:42 am
Former TeamSwift Admin
yes you do need to remove the intake & bore/grind the hole bigger ..
also the nissan tb's vary .. eg. some require some modification to make the suzuki tps sensor fit and others need bits like the hole in the throttle plate welded over.
the 60mm sr20 tb i got recently from daley was a direct bolt on, however it doesn't have a seperate idle screw, so the idle has to be set by adjusting the throttle stop & then repositioning/recalibrating the tps sensor.
PostPosted: Sun Jun 06, 2004 8:40 pm
Don't know if anyone else has tried this but the shaft from a standard gt t/b will fit in the 60mm t/b (mines off a 240sx I think) i.e. no modification of the tps button required and you don't have to put the tps on upside down. The only thing is the slot for the butterfly will have to be made longer to slide the 60mm butterfly in but the screw holes line up perfect. Think this can be solved with a drill press fairly easily. It's probably more work this way but it allows you to use all your suzuki linkage. Not quite done tinkering with it as I'm putting an idle screw in it. I can post up some pics or send them to Kris if anyones interested. Also hacking up a STR competition H**da fuel rail for the swift. Takes very little work and they bolt right up no problem.
"the Dali Lama told me that on my death bed I would regain total consciousness.....so I've got that going for me"
PostPosted: Thu Jun 10, 2004 11:05 am
Mama Said Knock You Out!
yes, post some pics. I'll try that on mine tonight.
PostPosted: Fri Jun 11, 2004 12:26 am
Ok threw a few pics up in my personal album http://www.teamswift.net/album_personal.php?user_id=250. Still haven't got the idle screw in it. Only issue I need to address on it is where the throttle stop is. The stop on the shaft doesn't quite come out of the tb enough, so when you tighten it all up the shaft won't rotate. Might not be an issue on the sr20 tb. Haven't taken mine off my car to check yet. Some material will be removed or some spacer added to fix this when I get time. I opened up the shaft to accept the 60mm butterfly with a quick pass of a sawsall. Spacers are $.65 aluminum spacers from hardware store. The rail is pretty simple. Cut off extra brackets, drilled out mounting holes to size of suzuki bolt and ground out a channel so they'd slide in and tighten. Counter sunk the bottom of the mounting bracket so the little plastic spacer will slide in. Ground out a hole so the injector can rotate. There's a chamber for this on one end but not the other. I've got cosmetic stuff left to do on it now. Clean up my channels sand it and polish it. Just did it real quick to see if it would actually mount up. When these are totally done I'll throw in some good pics.
PostPosted: Tue Jun 15, 2004 9:58 am
I got around to checking the swift TB shaft out. I got it in, and opened up the hole in the middle to fit the larger throttle plate. Fits great. I just had to grind down the shaft a bit to get the throttle cable assembly to slide down the shaft a bit more. I eliminated most of the ridge that stuck out and stopped the assembly from going further down. I should be done with it tonight.
PostPosted: Wed Jul 07, 2004 12:04 am
Ok. Here's my just about done TB. I found on the 54MM TB you don't need to fab up a throttle stop. Just use your old swift one!! There's 2 holes (http://www.teamswift.net/~geozukigti/tb/tb3.jpg) un-threaded that are in the exact same postition as the ones on the swift TB that held the throttle stop. So I tapped some threads in there, bolted the bad boy in, and it fit absolutely perfect. Even the cutout for the spring pin was in the exact right postition. And it stops the TB from opening past 90 degrees perfectly with the huge flange on the back of the throttle stop. Here's the rest of the pictures. Oh, and I used the throttle plate shaft from the swift TB also. Just used my grinder to open it up a bit. Now I just gotta see if I can find a home-made way of doing the throttle postition sensor. Oh, and you need new, longer studs to fit the new TB to the intake manifold.
http://www.teamswift.net/~geozukigti/tb/tb2.jpg
http://www.teamswift.net/~geozukigti/tb/tb1.jpg
http://www.teamswift.net/~geozukigti/tb/newstuds.JPG
PostPosted: Thu Nov 04, 2004 8:06 am
so i have to use the TPS of the GTi? right?
i will get a s13 tb
PostPosted: Wed Sep 26, 2007 9:41 pm
Ive already begun collecting the parts needed to upgrade my AFM and TB.
I already have a "SUZITech" 49mm AFM and "MALPASSI" fuel pressure regulator sitting in my room while i figure out what size TB i should use.
Ive read that people are using 60mm NISSAN SR20DE TB's, but ive also been told its pointless using a 60mm TB if the AFM is max bored to 49mm.
I have a mate that has several NISSAN TB at home, but i want opinions on what size is best suited for this setup.
Is it also a neccesity to use a Fuel Pressure Reg in this setup as the car will start to lean out ???
How do i go about checking the Air/Fuel Mixture ???
Thanks,
Nick
PostPosted: Wed Sep 26, 2007 10:21 pm
The Smuggler
Wow Nick
You woke up a very old thread.
Hope the guys can answer your questions.
"I also love the 7500 rpm scream of a DOHC" :razz: 2X 1989 Swift GTi's a 92 and Jr's new 93 GT
And I love this one!
PostPosted: Thu Sep 27, 2007 9:16 pm
Haha, yeah i noticed... Ive only had my Swift for about 2years and the last year or so ive begun to focus on getting engine work done, but i dont earn very much so im trying to get alot of work done by myself, my mechanic cousin, and a mechanical engineer freind, to try and keep labour costs as low as possible. But obviously some work needs to be done by professionals.
Im trying to reach my target of 100HP ATW naturally aspirated, the only dyno run i did, the car made 75.2 HP ATW, before 4-1 extractors, aftermarket ignition, coil, tach adapter and full major service.
Ive heard people net good gains in power from AFM and TB modifications, for a reasonable amount of money. Some bigger cams are also on the "To Do List", just waiting for a set of BD10's to come up second hand at a good price.
Thanks,
Nick
PostPosted: Mon Feb 18, 2008 9:40 am
If I bore out the standards TB would I need to modify or change the standard butterfly ??
http://www.facebook.com/profile.php?id=551883908
PostPosted: Tue Feb 19, 2008 11:29 pm
YES
PostPosted: Sun Nov 18, 2012 10:26 am
can anyone tell me the maximum bore size on a stock gti throttle body? 50 or 55???
http://www.cardomain.com/memberpage/811447
PostPosted: Tue Nov 20, 2012 10:22 am
About 50-51mm. Never seen anyone take it out to 55mm
ImageET 13.138 at 120.2mph
PostPosted: Sat Nov 24, 2012 9:30 pm
ok thanks
PostPosted: Thu Dec 06, 2012 8:15 pm
will the stock throttle body bored to 50 or 51 work great on a mild engine?? than the 55 nissan?? , like i have
i got the g10 stock single pulley and better exausth and a mushroom type filter in the maf, and i3 ecu chiped in toms rally chip........................
i don´t wan´t to go crazy about the throttle cause i have almost no mods
PostPosted: Mon Jan 21, 2013 4:10 am
just bored out the stock throttle to 52 and it works great :mrgreen:
PostPosted: Tue Jan 22, 2013 7:29 am
I tried this too but couldnt get it to idle properly, did you have any idle issues ?
PostPosted: Tue Jan 22, 2013 8:15 pm
i had to adjust the iddle screw and tps properly, but works great
but i have tom´s rally chip
how it was after the overbore to 52
