It is currently Sat Nov 25, 2017 4:50 am
Post new topic Reply to topic  [ 8 posts ]
PostPosted: Sat Mar 17, 2012 5:09 pm
anyone know if there is a repair manual available for body and mechanical part repairs?
I downloaded sF310 workshop manual which only seems to deal with engine, electric system and aircon.
I want to repair the driver window regulator
The previous owner said it suffered from usual sticking problems but it would appear the mechanism hasnt been bolted in properly and is bit messed up. The glass slipped off the runner when i fully lowered it and was a **** to get backup at dusk with no idea how it worked., I got it up and then taped the thing until i had time to look at it properly.
Prob is i could do with diagram or pics to show what is bolted where and to check if everything is as should be before spending money on a new regulator
are there more manuals out there??
PostPosted: Sat Mar 17, 2012 7:38 pm
i can get you the pics from my factory service manual, which i used to get mine replaced. however, you should promise to buy yourself a set later. it costed me about $130 for two volume set.
PostPosted: Sat Mar 17, 2012 7:43 pm
your car comes with a 3 volume set. exciting !
http://www.faxonautoliterature.com/1998 ... 13951.aspx
PostPosted: Sun Mar 18, 2012 6:44 am
Thanks for link thesilverbullit I promise myself to buy the 3set manuals to if only to take everything apart, break it, buy expensive spares and break it again.
In the meantime so I can get on with the job of fixing this currently taped up window could you please send a few scans of the appropriate pages inlvolving window reg changing. Mucho thanks
ps if there is a page on the rear wiper (also being prob) that would be so kind ta
PostPosted: Sun Mar 18, 2012 9:57 pm
first of all, learn to use the forum and search everywhere obvious for asking a question. second, never post broad, generalizations like 'repair manuals' when the subject of your post is completely different. third, after i'm going to post details about the rear wiper, just don't piss off and never visit these forums again, give back as best as you can.
viewtopic.php?f=2&t=17205 window reg repair
PostPosted: Sun Mar 18, 2012 10:03 pm
viewtopic.php?f=30&t=53351 rear wipers
PostPosted: Sun Mar 18, 2012 11:08 pm
....jv&s
PostPosted: Tue Mar 20, 2012 4:33 am
point taken .. thanks. will try to document fix and post.
