A quick and general lesson for others...<br><br>"Generally" manufacturers rate engine horsepower at the flywheel. That is, your motor is basically sitting there on a stand before it goes through the drive train on the car, the exhaust, and various things. <br><br>When you put it on the dyno, you have losses all through the drivetrain to consider and because of the specifics of different drivetrains (AWD, RWD, FWD) there are different losses for every vehicle. After the power the engine is making finally makes it's way to the ground there are generally from 15%-30% losses. In order to find out how much horsepower you are making at the flywheel, you have to know how much power you are losing through the drivetrain.<br><br>For example, our Gti engine is rated at 100hp at the flywheel. So Let's say a 100% stock GTi went and dynod 84hp@wheels, we could say that 84% of the power that is at the flywheel is making it to the ground. That means that if hte manufacturers ratings are correct for flywheel hp, there are 16% losses in drive-train to be assumed on a GTi (my car dyno'd 84hp@wheels with good condition motor and intake/exhaust... how much intake/exhaust added over stock... who knows. I haven't seen a 100% stock GTi around here for a long time). <br><br>So now you go slap on a junk-yard turbo on your once stock GTi and you dyno 151.7hp@wheels. Seeing as you already have your figure for drive-train loss on your car you would just go 151.7hp/.84 and you would get a magical 180.6hp@flywheel. If I didn't know any better I could assume even more losses and assume more flywheel horsepower.<br><br>Assuming 16% losses on our cars would actually be fairly low, but it's quite possible. The only true way to know would be to dyno a stock GTi engine out of the car at the flywheel like the manufacturers do, and then dyno it in the car. The reason I suggest that is because manufacturers flywheel horsepower numbers don't always match up when production comes around. <br><br>To give an idea of how drive-train losses from car to car can vary (even both FWD/RWD/AWD), here is a comparison of my car vs. a FWD Type R VTEC which is rated at 190hp (this Type-R is not stock either, but on the same dyno with close to same run conditions). You'll see that I have way more torque and only a few less peak hp. <br><br><!--EZCODE AUTOLINK START--><a href="http://www.angelfire.com/ky3/teamswift/swiftcomparison.html">www.angelfire.com/ky3/tea...rison.html</a><!--EZCODE AUTOLINK END--><br><br><br> <p><!--EZCODE FONT START--><span style="font-size:xx-small;"><!--EZCODE BOLD START--><strong>Kyle Jones<!--EZCODE LINK START--><a href="http://www.angelfire.com/de/ksj/myswift.html"><br>Junk-Yard Turbo set-up, formerly NOS-fed, constantly evolving 1989 Suzuki Swift</a><!--EZCODE LINK END--></strong><!--EZCODE BOLD END--></span><!--EZCODE FONT END--><br><br></p><i></i>
