It is currently Sat Nov 25, 2017 1:34 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Mon Dec 13, 2004 9:09 pm
http://www.discountedwheelwarehouse.com ... erence.cfm
PostPosted: Fri Dec 31, 2004 6:27 am
Dodge Colt and early '90s Honda Accord Wheels will!!
1993 GEO METRO 1.0 lsi (xfi swap)
1995 Eddie Bauer Exploder
1983 CHEVY C-10--the gas guzzler
1997 VW GTI VR6 Turbo--dead as a door nail
1994 GEO METRO 1.0 xfi (retired and parted out)
1989 Suzuki Swift GTi (sold)
 Post subject: wheels
PostPosted: Sun Jan 02, 2005 11:12 pm
Nissan 4 lugs mostly. I got Infinity G20 wheels on mine.
Frank
PostPosted: Tue Jan 04, 2005 6:30 pm
A search can turn up many different results.
Mazda 323 rims fit, as do RX-7 'telephone dial' rims. Also, Ford escort rims fit. I saw a set or escort gt rims on a 323 the other day, so it should match our 4-bolt pattern.
92 Suzuki Swift GT - In the car hospital. :(
92 Geo Metro 1.0L 5 door - back on the road!
PostPosted: Tue Jan 04, 2005 10:07 pm
a.k.a Bum head
That's 'cause the 323 and the Escort were practically the same cars (and would mean that the wheels will fit our cars... heh heh...). :P
Chris
Good stuff for sale!
viewtopic.php?f=15&t=42901&start=0
PostPosted: Wed Jan 05, 2005 10:24 am
Only 86-89 Escorts and 323's will work. The 90+ use the smaller 4x100mm bolt pattern.
Also Ford Tempo and Mercury Topaz wheels fit (same as Escort) and I know the 74-93 Mustang wheels are the same bolt circle but the offset may be wrong.
M3----"M" body "3" cylinders.
Now Turbo'd
"M3 like the BMW?"
"No, like the Gillette razor."
PostPosted: Thu Jan 06, 2005 7:23 am
I've watched this thread for a while and waited to see who would bring this up - the "bolt pattern" or more correctly - the PCD (pitch circle diameter) is only ONE of the things that needs to be considered when selecting wheels - the rim diameter, width and offset are just as crucial.
There are probably a hundred or so older Toyota models - the rear wheel drive ones - with the correct PCD, with suitable rim dimensions, and incorrect offsets - they may or may not fit, but even if they do fit & clear the suspension and body, what effect do they have on your suspension geometry? Do they affect the track? Do they affect the scrub radius of the steering?
On the other hand - I can locate 10", 12" rims with the correct PCD, that you're not going to get onto the hubs - period.
PostPosted: Thu Jan 06, 2005 12:30 pm
Former TeamSwift Admin
if anyone ever used the search button ....
check this thread
http://www.teamswift.net/viewtopic.php? ... wheels+fit
another big issue is the hub center bore, gti hubs are ~60mm anything smaller won't fit, however i'm pretty sure the non-gt/gti's have a smaller hub circle ..
as long as the wheels are no wider then ~6.5" then an offset of around 35-40mm usually works, i'm not sure about the exact backspacing required.
Daley wrote:
i have mazda 323 GTX turbo rims on my car and they are perfect. the only part is that you have to hone some of the centre of the wheels out, but just a little bit.
 Post subject: rims
PostPosted: Thu Jan 13, 2005 9:06 am
I have a set of alluminum rims from nissan stanza 15" will bolt right on. you need p195 50 15 tire to fit the wheelwell, pay for shipping and send me a box of Canadian and they be yours!!!!!!!hehe :D
PostPosted: Sun Apr 17, 2005 9:30 pm
Mine came off an old Saab
PostPosted: Sun Apr 24, 2005 2:26 pm
Mine as well.
1997 SS
[email protected] with 90 shot
[email protected]
253.8 RWHP
378.6 RWTQ
1985 355 powered Sonoma.
13.6 @ 98mph
PostPosted: Wed Jan 18, 2006 9:34 pm
Village Idiot
looked rediculas...and you would have to cut the fender a little...but they fit...
they are 215 60 R15"
Sincerely'
Alex B.
1993 Geo Metro 3 banger
Stripped Shitter
 Post subject: Kosei 17" Chrome alloys
PostPosted: Wed Feb 22, 2006 5:51 pm
Hi everyone. Does anyone know anything about these wheels.....
http://cgi.ebay.co.uk/17-inch-Kosei-Chr ... dZViewItem
The offset is right but i dont know anything else about them.They nice tho, arent they?
I realise I would have to have the arches rolled.
PostPosted: Mon Mar 20, 2006 11:04 am
So what is the bolt pattern? I'm looking to get some cheap 14" rims for my 92 Metro.
1989 MR2 - 20v ST & C56 5 speed, MS&EDIS
1993 Grand Cherokee - 5.2 V8, intake, exhaust, and 31"s
PostPosted: Mon Mar 20, 2006 11:27 am
a.k.a Bum head
Odd that no one posted that directly in this thread. It's probably in one of the links that n1tr0 posted a bit earlier though. Anyway...
4x4.5" is the pattern. Lugs on a 3-cyl Mk2/3 metro are 10mm, all other lugs ought to be 12mm. Keep this in mind when you get new nuts, since you'll either need ones with a wider shoulder if you've got an Mk2/3 Metro or you'll need to use thick washers to take up the slack (temporarily) before you upgrade the studs to 12mm.
No one can convince me that using nuts with wider shoulders or using washers is a 'safe' method of taking up the extra slack when you have 10mm lugs.
Chris
PostPosted: Mon Mar 20, 2006 11:35 am
hahaha I'm used to seeing metric bolt patterns, and you're in Canada, and you post standard :lol:
PostPosted: Mon Mar 20, 2006 12:14 pm
a.k.a Bum head
That's 'cause I can't remember the mm conversion equivalent (and I didn't want to give out the wrong info). ;)
Chris
PostPosted: Mon Mar 20, 2006 12:23 pm
Ok, thats the 4x114 one. Strange... I thought it would be 4x100!
Ok, so I'm looking for 4x114 with 35-40mm offset?
PostPosted: Wed Mar 22, 2006 2:06 am
Moderator & FAQ King
Actually it's 4x114.3 :wink:
( miracle pour hole)
maybe a picture Thanks
PostPosted: Mon Jul 24, 2006 11:45 pm
Hey guys does anyone know where the post on wheel weights went? I had it bookmarked a while back but its not there anymore. Also on the on the Rx-7 wheels I would like to, very respectfully, ask that they be left for the Rx-7 owners as they are becoming rather difficult to find.
Thanks, J.
96 Metro 1.3 auto, dd
94 VFR 750 Interceptor, 2fast
87 BMW 325is, WAR chip, 3" MAF swap, pnp, cammed, I.E. roller rockers and ss valves.
72 VW Baja Beetle, one crazy ass bug
69 Columbia C36, Home
PostPosted: Thu Jul 27, 2006 9:09 am
2" weiner
And for th Aussies.. TM Magna (mitsubishi) will fit, but you need hubrings for th centre alignment....and also Sigma (mitsubishi) and Toyota cressida (early models) and also Nissan Pintara and Bluebird, dont know about th offset and hubcentre on these, but th general PCD is right
manaibve wrote:
I need the following.....rear defrog switch-
thatll keep the slimy little beggars off the hatch glass :lol:
PostPosted: Wed Aug 02, 2006 11:18 pm
i have a 1996 firefly, and my chrome rims from my 1991 mustang bolted on, but i couldnt find any tires small enough to fit them and not scrape my fenders :(
1996 Firefly Hatchback, 1995 4 cyl engine.
Beast in the making.
PostPosted: Fri Aug 04, 2006 12:46 pm
Village Idiot
how about rims from mugen(honda) or 1996 nissan sentra 5spokes.or the new suzuki forenza multi spoke.
nucking futs!
my car is blood thirsty!
GIT-R-DONE
 Post subject: stud sizes
PostPosted: Fri Dec 22, 2006 1:33 am
on the earlier sprints n firefly's its 10 x 1.25 ... on the later ones its 12x 1.5mm ... oh yeah im a professoinal tire guy .. 15 years in the biz... 8)
 Post subject: Re: stud sizes
PostPosted: Fri Dec 22, 2006 6:10 am
Then you should know that it's 12 x 1.25mm. :P
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
