It is currently Fri Nov 24, 2017 3:54 pm
 Post subject: Rust Repair!
PostPosted: Fri May 25, 2007 10:58 am
Before I get started on my rotisserie build for rust repair, floorpans, rockers, door skins and the like. Let me get some feedback. I have 32 years as a journeyman welder. Am good at what I do. If there is a need for this service here on TeamSwift then I will get started on my rotisserie,(will be built exclusively for Suzuki/Geo vehicles) My work will speak for itself. I'm located in the Detroit/Dearborn area of Michigan. At least for now. I hope Corbin Ky in the future.
Thanks, George.
If I Can't Weld It.....It Can't Be Welded!
 Post subject: Re: Rust Repair!
PostPosted: Fri Jul 24, 2015 5:07 pm
did you ever move to ky? im in ky and im trying to restore a rusty 01 swift.
PostPosted: Fri Jul 24, 2015 7:45 pm
just in case you didn't notice, that post is from 2007, and when you click on someones profile you can see when they last logged on, which in this case is 2011, so I doubt you will be hearing back :ez_eek:
___________________
89 Swift gti
