So I'm selling most of my spares to fund my project. Pictures speak better than words so here it goes...
1,2 - Red powder coated front Gti brake parts
$10 each3 - Front Gti caliper
$20 (probably needs new cylinder seals)
4 - Mk2 left rear light
SOLD5 - mk2 right rear light
SOLD (one of the bolt-holes is too big)
*or the set for
SOLD6 - Mk3 right rear light
$15 (was hit/cracked a little)
7 - Mk3 left rear light
$25*or the set for
$358 - Passenger-side power window plastic
$109 - Alternator cover
$1010,12,13 -
$511,17 - Driver-side door-latch
$10 each14 -
$10 each SOLD15 - Rear middle light
$2516 - Rear middle light
$15 (bolt-holes too big)
18 - Driver-side window rail
$519 - Windshield wiper motor
$1520 - Driver-side power window
$25 (glass is broken)
21 - Driver-side door handle
$5Attachment:
22 - Steering rack & pinion with tie-rods
$5023,25,26 - 1.3L oilpump
$15 each
24 - 1.6L oilpump
$20 SOLD27,28,29
$530 - intermediate shaft and bearing carrier
$25 SOLD (bearing seems to be good)
31 - Front control arm bushing bracket
$532 - Crankshaft keyway for SOHC models
$1033 - Rear strut-cover boots
$5 pair34 - 1.3L DOHC and SOHC cam gears
$10 each35 - Gti box crownwheel
$1036 - 1.3L SOHC camshaft
$50 SOLD37 - Stock Gti exhaust manifold
$1538 - Gti head in nice condition (recently removed from a great working engine)
$200 SOLD39 - Only some parts left: valve cover
$25 SOLD and cams
$40 SOLDAttachment:
40 - Front gti shocks with cut springs
$15 each Rear shocks $10 each
41 - Mk1? A/C compressor bracket
$1542 - Mk2/3 A/C compressor bracket
$1043 - A/C compressor
$50 viewtopic.php?f=15&t=56668&p=431314#p43131444 - Gti flywheel
$2045 - Front uncut Gti spring
$1546 - Rear uncut Gti spring
$1047 - Gti speedo sensor
$1048 - Main fuse-box with surrounding harness
$1549 - Gti knuckles
$45 for both viewtopic.php?f=15&t=56854&p=425889#p42588950 - Driver-side window rubber
$551 - Rear spoiler
$20 (was apparently ripped from hatch, needs new brackets glued down/fitted)
FuLL A/C system:
viewtopic.php?f=15&t=56372&hilit=+systemMore parts:
viewtopic.php?f=15&t=54106/ All prices EXCLUDING shipping-costs. Open to offers if you buy a lot of stuff. Willing to trade for performance parts (just tell me what you have).
