It is currently Fri Nov 24, 2017 12:30 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Oct 15, 2013 7:38 am
I dont know how come that was happening, but I got it sorted out. Thanks
PostPosted: Wed Apr 09, 2014 7:37 pm
Which type would be best suited for the 1/4mile track?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Wed Apr 09, 2014 8:20 pm
welded???
___________________
89 Swift gti
PostPosted: Wed Apr 09, 2014 8:47 pm
i thought only offroad guys used the Lincoln locker =)
08 Civic Wife's car
PostPosted: Fri May 02, 2014 2:42 pm
Anyone was able to contact Balli this year?
Mk3 GTi Saudi Arabia edition.
PostPosted: Fri May 02, 2014 3:21 pm
october 2013 was last time i talked to him..
try email: [email protected]
PostPosted: Fri May 02, 2014 5:22 pm
I see he last visited this site 3 weeks ago, definitely pays to email him.
PostPosted: Sun Jun 22, 2014 1:00 am
would any of them fit in a 92 1.0 vert
02 bmw 330ci zhp
'91 Geo Metro Convertible 5-speed parts car
'92 project squishy viewtopic.php?f=36&t=43375
'98 Chevy K2500
'76 Harley Davidson FXE
PostPosted: Sun Jun 22, 2014 1:47 am
Sure, it will.
I use this diff since last week and looks very promising. Waiting for trackday session to check it on tight corners :)
PostPosted: Sun Jun 22, 2014 4:21 am
i'm using it atm together with 4.9 FD and i love gearbox.. did rally recce last weekend with it and it was almost more fun than actual race :P
also i went once to hill climb "track" with 3 people in car and street tyres.. it went really well around hardpins..
but for rally use (with protlum gas shocks with bulbs, 80% tarmac, 20% gravel, with holes, bumps and corner cutting setup) it's not even close to plated lsd.. but for 100% tarmac setup with stiffer springs should be ok..
PostPosted: Tue Sep 23, 2014 1:28 am
Hi All,
I'm in the business sorry for the rare forum visits.
I have Suzuki torsens on stock now, ready to post.
Also have finalized AWD torsen set (front and rear torsens) on stock now.
Please ask in mail: :arrow: [email protected]
PostPosted: Tue Sep 23, 2014 3:07 am
I reccomend it! Very good built quality, works completely as expected (I use torsen) and price is also very good.
PostPosted: Thu Nov 06, 2014 11:36 am
AWD Swift sets (front-rear) ready to post.
Gti torsens also avaliable from stock now.
PostPosted: Wed Apr 22, 2015 1:44 pm
AWD torsens (front and rear) available from stock now.
PostPosted: Sat May 09, 2015 10:59 pm
I'm really happy with my Gti LSD, the car is far better now, thanks!
PostPosted: Mon Aug 17, 2015 1:44 am
Will this work in mk1 mt?
-vernon wasser-
88 sprint, 4dr sold :(
87 turbo 2dr, never ran :( :(
86 sprint, 2dr current DD! :)
PostPosted: Mon Aug 17, 2015 5:04 am
Not quite, the mk1 diff is fractionally narrower(3mm I think), you can machine out the mk1 case slightly or modify the diff to take a bigger diff bearing.
PostPosted: Thu Aug 20, 2015 10:42 pm
Actually bearing ID and OD is the same, it's the thickness
of the bearing that presents an issue. If you use the OE
bearing, the case halves will not close, the interference
is approx 4-5 mm.
You would have to grind the inside of the case to clear the
width of the body of the LSD, switch the bearings from a
17mm thick to a 15mm thick carrier bearing, delete or
partially machine the speedo drive gear to a hat shape
and fudge a spacer or two to get it to fit, even then
it's very iffy. Mine's done with all the above mods and
installed, but have not fired it up yet or tested.
It may have been easier to have had the case halves
machined to fit the extra width with the OE bearings,
but probably would have still had issues with the speedo
drive gear. I am told the Cusco clutch type diff is a bolt
in swap which may be better for the track, but opinion
on Bali's diff is it's better for the street.
I'm working hard to get this rebuild back on the road
this year, but don't have any actual results yet.
PostPosted: Tue Aug 25, 2015 8:43 am
I have read that this is a torsen diff with a preload. My question is: does it work when one wheel is in the air? Quaife-like diff in this situation would not work, while the clutch type diff would still pass the torque to the wheel which has grip. What is the behavior of your diff in tthis kind of situation?
PostPosted: Tue Aug 25, 2015 10:16 am
Balli makes both a Torsen-Quaife style and a clutch type LSD. You are correct that the torsen diff will not work with a wheel in the air, but the clutch-type diff will.
If you are interested in his products, I suggest contacting Balli by email (listed above).
PostPosted: Tue Aug 25, 2015 11:15 am
quaife use preload rings too..
it's not enough to go with one wheel in air (or broken axle) but it helps going overcrest, over holes and so on
i use it in my street car.. it could be ok for circuit or hillclimb because of hard suspension and nice road, but for rally clutch/plated type is the way to go :wink:
PostPosted: Fri Oct 16, 2015 1:56 pm
Sorry Mates I have no time for forums.
Lukak told right. The pre load (and the moment of inertia) will drive on short holes but with broken axle the torsen will not lock the gears. It's totally enough in racing but no way for heavy duty off-road.
The mk2 can be prepared into an mk1 box but better way to make an mk1 shape torsen. (I can)
Now I have mk2-3 torsens on stock. And some 4WD too.
PostPosted: Sun Oct 18, 2015 11:25 pm
hi!
the price for 1989 gti gearbox!
regards
PostPosted: Mon Oct 26, 2015 5:07 am
Swift CR wrote:
hi!
regards
PM sent
PostPosted: Wed Nov 08, 2017 5:43 am
I have torsens on Stock now, ready to go...
