"The perfect ignition advance setting is as much advance as possible, with a faint hint of ping on occasion."
Usually, yes.
I use an emulator to play with fuel and timing maps on a Cultus ECU that can switch maps based on a signal from the knock sensor. I'm using this setup to run a g13b engine with stock internals (no JDN Cultus pistons), however. The JDM setup is indeed knock limited or presumably there would be no need for a knock sensor.
But...
While I've had to rely on others to do dyno testing for me, on US market 93 octane pump gas and stock compression, the g13b engine with non-Cultus internals is not knock limited, i.e. you can advance ignition beyond the value that gives maximum torque without experiencing significant ping, so no need to advance until you hear it. Another reason our engines did not come with the knock sensors too, I suppose.
That may not be true with lower octane ratings, and may also be dependent on the map.
It's also still a good post, but I thought I'd chime in for the benefit of experienced tuners and let others know that, in my experience, if you want to make the most power on an export-market g13b, you'll need a dyno to optimize timing or use a map that is known to work for stock internals. That's not to say you can't just twist the distributor a bit for more power, in fact, there's a pretty healthy margin of error, so go for it. Only a dyno can tell you when you've got it dialed-in, however. That's more or less true anyway, but you can get really close to the most effective timing on many engines by tuning for the edge of ping. Not so here, as far as I can tell.
Anybody disagree? I'd love to hear another perspective, as though I've worked with others that have spent time on a dyno that supports what I'm saying, the dyno time to absolutely confirm this on my own is too expensive for me.
Yet another reason to build it with high comp pistons
