| 91 ragtop wrote: Will these work in a G13B with a 75MM overbore ? What would the compression ratio end up at ?http://www.ebay.com/itm/191761498016?_t ... EBIDX%3AIT Ken.............Depending on the dish of the piston, between 7.3-7.9:1.  Pretty low.viewtopic.php?t=24954 I've read somewhere people shaving the block 1mm to raise the compression while using vitara pistons. Because that's the distance the vitara pistons keep from reaching the top of the block._________________
 2003-EVO7 GT-A
 Aruba "one happy island".
