1994 geo metro, 3/3/3, factory black. good trans, sick engine 211,000 km
and then a 87 Pontiac sprint-3/3/5- good engine, trans-326,000 km, well maintained, rough interior
the 94 is smashed on the front-end, bent upper and lower rad supports, smashed windshield. rest of the body is dime straight. not written off, she was still driving it when I purchased it.
the 87 has a good body, perfect windshield, decent tires, decent oil pressure at idle hot (27 psi) p.o installed manual volt and oil pressure gauges. interior is sun baked/cracked here and there.may need a clutch soon.
might be in the market for some mk1 parts
found this one 3 blocks from work-3/5 , decent body, needs glass, top, tires, possibly a motor. no keys.
180/160/80 comp. started right up (HOTWIRED)
