I put larger wheels and tires on my metro convertible and now sometimes if there is too much weight in the trunk the rear tires will rub in a sharp corner or on a bad bump in the road. The rubbing is on a soft spot inside the fender so I'm not worried about cutting the tire but I don't want them rubbing on the body.
I've already put in spring spacers but the rear springs are weak and sagging. It's time to replace them. So what I need to know is, is there a taller and stiffer rear coil that will fit in the 91 Metro convertible automatic transmission? I'll just get a new alignment after I get new springs.
