It is currently Sat Nov 25, 2017 10:30 am
 Post subject: the new dutch guy
PostPosted: Sun Nov 08, 2015 8:04 am
hello i am louwie awd ( louwie for short)
im driving a subaru justy awd 1.3 sohc g13b with 68hp.
this is not a lot of power but with a small turbo in the future this wil help a little.
my ecu is  a: CO 1.3 4WD EEC
33920-69E50 MB112000-4492 12V this is a denso ecu.
and already a question...:
i need a pinout for this particular ecu because i want to instal a BEE-R Rev-limiter
i know i know its bad for the engine but its to mutch fun the looks on there faces when i launch the  car!
can anybody help me with my problem?
for the bee r i need rpm signal, camshaft signal or cranksignal.
please help
i wil post a few pictures on the next post
 Post subject: Re: the new dutch guy
PostPosted: Sun Nov 08, 2015 11:54 am
Hi and welcome to teamswift.
I don't think I've ever seen a pinout for that ecu here. Is the engine a sohc 16valve?
Maybe you could search in the appropriate section.
A twin cam (gti) should be more fun in that justy.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Sun Nov 08, 2015 2:23 pm
If it's only 68 hp I'm thinking it is a 1.3 8 valve engine.
Ken........
PostPosted: Mon Nov 09, 2015 1:41 pm
It has a rev limiter from the factory. The fuel pump will switch off.
PostPosted: Tue Nov 10, 2015 3:59 pm
i found the ecu pinout! jeej! and yes its a 8v indeed.
the rev limiter is ajustable and can be used as a launch control.
(anti lag)
but im stil in dought about the engine swap because there hard to find in Holland.
a small turbo setup is almost cheaper or the same as a gti swap.
turbo is a TD04 from a impreza gt. ( not installed yet)
Users browsing this forum: Google [Bot] and 2 guests
