Welcome to Teamswift, A 98 swift for $150.00 could easily be scrapped out to get your money back, should you get in over your head. But just a couple random thoughts, 1) tires, I am a used tire dealer (Courtasy tire, Brainerd MN) both 155/80r-13 and 175/70r-13 (an alternate size that I find preferable) tires are becoming very difficult to find used ,especially sets or pairs. so you might want to figure an addl.$150.00 to $200.00 just for those If you end up having to buy new. 2) Headlight issue; does it need bulbs ? (cheap but unlikely both are bad) or are the capsules damaged? figure $30.00 to $50.00 each here or on GMF or your local yard. Or are all the components in place, and not working properly? if so. this can be a Can of worms. with a bad headlight switch in the steering column being a common suspect. If so, You might want to nose around the "problems and fixes" threads, as I am sure it has been addressed by some of our better minds. Also I sure I along with others would be interested to know this cars configuration. 2dr or 4dr ? 5 speed or auto. ?
Again, welcome to teamswift, Best wishes, Jonathan
_________________ Current stable: 1987 Sprint Turbo (Porsche Guards Red) 75k 5sp,AC, w/cruise, Resto-Mod,owned since 1997) (looking for dash-pad) 1989 GTI (white)104k 5sp,AC (Resto-mod completed 1999). (looks great, But rusted out ,need clean southern body.)Help!? 1991 Vert (red) 129k 5sp,AC, Resto-Mod, 75% Done.(Clean SW car) 1993 GT(Teal) 103k 5sp,AC,w/PW (Resto-Mod,60% done.)(Clean SW car) 1994 Swift GS 4Dr sedan (Painted 2005 Ford Kona Blue) 95k 1.3 SOHC 5sp
