I found it was worth the time to fabricate parts to convert to MPFI and standalone. Hacking the ECU took a lot more time than I spent in the shop making wiring harnesses and fuel rails.
But, with that said, I hope you get it working
You did the right thing, but you had a lot of factors working against you, not the least of which was working with a late model 3 cylinder and trying to go turbo. There aren't enough people tuning the three bangers, and though I'd like to break into the market for chipping them myself, there may be a reason nobody else sells one. I've looked at some photos of 3cylinder ecus on line and some of them have eproms and some do not--some are reflashable and others???? ECUs for essentially the same engine look nothing alike inside.
You would have gotten further "hacking" an ecu intended for a more similar 3 cylinder turbo in the first place, like a Canadian model, but by that time you are already monkeying with a wiring harness, so yeah. Not to mention that they are speed density to begin with, so less tolerant of a less than perfect fuel map, there are separate maps for EGR, and so on.
The G13B ecus already have a long history of chip tuning, so there really isn't a question of if it "will work". I've been playing with the fuel and timing maps on my GT successfully for years now, though I admit there are some limitations I wish I didn't have to work around (the most severe being the limited tuning space at high rpm
) How much extra power could I make by going to sequential injection or coil-on-plug ignition? I don't know, but certainly some. On the other hand, I got my Ostrich for $80 used and the only thing I needed to control my ECU was a socket.
Knowing the MAF curve does open up another level of possibilities too
I'm not even going to bother with speculating about what will work, but I'll definitely post back when I get some results.
