It is currently Sat Nov 25, 2017 11:25 am
 Post subject: Please Help
PostPosted: Sat Apr 05, 2003 5:15 am
I know most of u guys will take this for granted, but i need help from u guys to mount some side skirts onto my "stocko" GA swift<br>Any help would be greatly appreciated!!, i dont mind drilling holes etc, but dont really want to drill into the rear 1/4 panel side where u can see it, is there any way around this??<br>how do these things mount?? i only got the skirts no mounting stuff :/<br>Thanx again!!!!!!!!!!!!!!!!! <p></p><i></i>
 Post subject: Re: Please Help
PostPosted: Sat Apr 05, 2003 3:59 pm
I never mounted any on,<br>but couldn't you get away with just drilling a couple of holes, and sticking the rest on with liquid nail's or some similar product like that? <p></p><i></i>
PostPosted: Sat Apr 05, 2003 4:30 pm
Did you get gt skirts? I haven't taken mine off but I think the main mounting points are in the fender wells with screws. You might be able to get away with a silicone adhesive and some well placed screws. Don't know. <p></p><i></i>
PostPosted: Sat Apr 05, 2003 5:42 pm
Hi <br> On my 91 Sprint Turbo(scrapped), Under the door edge there is a thin steel strip from the front of the door to the rear it sticks out away from the boddy along the top edge and is riveted to the rocker panel along it's length,there are 2 screws ahead of the door and 2 between the door and rear fender,a number of sheet metal screws hold it in place under the rocker panel and up the fenders, there is a lip on the ground effects that slips onto and behind the strip of steel , there is also a tongue and groove soft plastic seal that runs the full length to seal the upper edge to the body,(silicone caulk should work here,) I am painting a set now to install on my 93 swift 3cyl . If you want a pic of the rocker of the 91 sprint or what I do to the 93 Swift to attach it ,I can get you one , Ian Have fun !! <p></p><i></i>
PostPosted: Mon Apr 07, 2003 1:00 am
Thanx guys much helps!<br>yea i got the gt skirts, just without any of the mounting bits :S i did however get the rubber seal that goes in between the body and the skirts thankfully <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <br>Thanx whiteliner for ur detailed response, confirms my fears that drilling seems to be the way to put it in, ive heard about the metal jutting out bit didnt realise it was riveted in :S<br>Id really apprecaite any pics u could send and would be extremely interested to see how u mount them on ur 93 swift, same model as mine <!--EZCODE EMOTICON START :D --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"><!--EZCODE EMOTICON END--> <br>thanx again!!!!<br>my email is [email protected] <p></p><i></i>
PostPosted: Mon Apr 07, 2003 10:47 am
I've emailed you the page from the factory manual on removal <p></p><i></i>
 Post subject: Thanx :)
PostPosted: Mon Apr 07, 2003 10:28 pm
Got ur email, thanx for that page it sheds some light onto the mounting "mystery" <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> <p></p><i></i>
