| ROV's MK1 Suzuki Swift Gti hillclimb car http://www.teamswift.net/viewtopic.php?f=14&t=39833 |
Page 5 of 7 |
| Author: | MF89 [ Mon Jun 18, 2012 9:33 pm ] |
| Post subject: | Re: ROV's MK1 Suzuki Swift Gti hillclimb car |
As a precaution, the timing belt is changed every year. |
| Author: | ROV [ Fri Jun 22, 2012 2:11 pm ] |
I don't do it every year because in total the car does less than 200 km. |
| Author: | PBC137 [ Mon Jul 02, 2012 11:29 am ] |
ROV wrote: Cosmetics...engine bay painted and the whole front of the car was spot welded .Also changed the gearbox. When you say spot welded, what is meant by this? I have heard of seam welding for racing cars...is this the same? I would like to do this with my celica alltrac. Any pics of the welds? Cheers! |
| Author: | ROV [ Tue Jul 03, 2012 10:52 am ] |
I cleaned everything the I welded 2cm with a 2 cm gap. From what i've heard continous welds aren't good for the car . |
| Author: | PBC137 [ Wed Jul 04, 2012 10:33 am ] |
ROV wrote: I cleaned everything the I welded 2cm with a 2 cm gap. From what i've heard continous welds aren't good for the car . Oh, is that because you would still want to have some degree of flex in the unibody chassis? |
| Author: | ROV [ Wed Jul 04, 2012 12:49 pm ] |
Exactly, if you weld everything without leaving gaps you could develop cracks around the weld since it won't have any room to expand or contract or flex. |
| Author: | ROV [ Sun Sep 30, 2012 2:22 pm ] | ||
| Post subject: | Re: ROV's MK1 Suzuki Swift Gti hillclimb car | ||
Some onboard action..just the practice run. I managed a new record time for engines under 1600cmc of 1:12.738 and finished 9th overall. http://www.youtube.com/watch?v=yeRAyE-XPyo
| Author: | MF89 [ Sun Sep 30, 2012 8:03 pm ] |
Hey, the motor sounds really strong and good |
| Author: | ROV [ Mon Oct 01, 2012 12:26 am ] |
Thanks. I took me 4 years of trial and error to get it that way. Running 38 max degrees advance with a comp ratio of 111 or 12:1 running 9.3 mm cams and 222 degrees. Carbs are dellorto dhla 40 with 34 chokes . Fuel was Rompetrol alto 101 available for the public , probably 98+ COR . I will now have to save money for an LSD, I don't know if you noticed on the vid the inside wheel that slips and slips although the slicks were warmed up and had a good grip around corners with part throttle applied. What kind of lsd do you think i need , clutch type or modena type? I don;t think I could run with a welded diff on that kind of track without power steering. |
| Author: | ROV [ Tue Oct 16, 2012 2:13 pm ] |
How much rpm can the gti distributor take? Mine got the protective cover off ,feel in the distributor cap and broke it. I was doing 9 or 10k on a burnout to warm up the slicks and it just died on me. |
| Author: | ROV [ Sun Nov 18, 2012 1:40 pm ] | |||
| Post subject: | Re: ROV's MK1 Suzuki Swift Gti hillclimb car | |||
This year ended rather badly , I missed 3rd and shifted to 1st while doing 9000 rpm in 2nd. Still no1 in the 1.4 class but the damage to the engine kinda put me down. This winter will be all about rebuilding the engine . P.S : The oil and aluminum fragments came through the carburetor trumpet....odd thing.The engine block is intact and there is no obvious engine knock.
| Author: | ROV [ Sat Nov 24, 2012 10:13 am ] | ||||||||
| Post subject: | Re: ROV's MK1 Suzuki Swift Gti hillclimb car | ||||||||
Unfortunately the engine gave it's best, nothing seems salvageable , I will have to check the crank for straightness and see if i can recover the arp rod bolts. The only things that are ok are the cams possibly the lifters and springs ,3 pistons and rods , possibly the crank ,all bearings since the wasn't knocking water pump oil pump . I think the cause of the failure was a valve that had a flaw or something .My next engine will probably have ss valves if they aren't too heavy. Here are the photos . I'll Be Back. ( copyright Arnold Schwartzeneger )
| Author: | Dattman [ Sat Nov 24, 2012 2:01 pm ] |
| Author: | ROV [ Sat Nov 24, 2012 2:51 pm ] |
Yep..that sucks. What are your thought in terms of ss valves. Do you think i should be running them?Can I run them with stock springs and lifters? Could this have happed only because i over revved it? Did you or have you heard any other guy running a g13b about breaking valves when hitting close to 9000 rpm ? |
| Author: | Dattman [ Sat Nov 24, 2012 7:02 pm ] |
Do you have a rev limiter? cutting the spark on over rev would help somewhat. I'm probably not the most qualified person to ask but I would say the over rev is what killed it, there other guys running well past 9000rpm but I think you need solid lifters at that rpm. |
| Author: | t3 ragtop [ Sat Nov 24, 2012 9:53 pm ] |
ding dong! that looks like the piston crown reached critical mass and the whole cylinder went up in a nuclear explosion. gets my vote for the "carnage of the year" award. |
| Author: | FlyingGrape [ Sun Nov 25, 2012 2:38 am ] |
t3 ragtop wrote: gets my vote for the "carnage of the year" award. +1. It's a late entry but looks like our winner this year. Sorry for your loss |
| Author: | ROV [ Sun Nov 25, 2012 4:20 am ] |
Yes , valuable lesson learned . No, i don't have a limiter , just a shiftlight. So, are SS valves a must for high rpm or was this just an accident? Enjoy the vids http://www.youtube.com/watch?v=KeNpqaMU6no&feature=plcp http://www.youtube.com/watch?v=dAp6RoLOP8Q |
| Author: | elbola [ Sun Nov 25, 2012 11:43 pm ] |
Talking about rpm's.... check this out http://www.youtube.com/watch?feature=en ... cPOn4&NR=1 |
| Author: | ROV [ Sun Dec 02, 2012 4:00 am ] | |||
I got a consent form my wife...what would the holiday spirit be without car parts...
| Author: | ROV [ Wed Dec 12, 2012 12:14 pm ] | ||
Carbs are all cleaned and rebuilt. Ready for the next year of racing.
| Author: | ROV [ Fri Feb 08, 2013 3:48 pm ] |
Just got new goodies for my car. steel flywheel 3.5 kg 4 puck disc 0.7kg exedy pressure plate 3kg Do you think that there will be problems with the gearbox, using the 4puck disc? |
| Author: | t3 ragtop [ Fri Feb 08, 2013 9:27 pm ] |
i hope not. i just bought a stage 3 clutch kit with a 4 puck friction disc. it has copper ceramic pucks. |
| Author: | Dattman [ Fri Feb 08, 2013 10:24 pm ] |
Just make sure you carry some spare driveshafts in your tool box when using that 4 puck clutch |
| Page 5 of 7 | All times are UTC - 5 hours |
