It is currently Thu Nov 23, 2017 11:45 am
 Post subject: DIY Seat Lowering
PostPosted: Fri Sep 17, 2010 4:31 am
We all have heard people say "Im 6 foot tall i wont fit in a swift". I have always thought that the seats sat too high in the car, with a racing helmet on i only had an inch between the helmet and the headliner. I then decided to lower my seat after searching for hours on lowering the seat and aftermarket seat installs and not finding anything on the topic. All you will need is some scrap metal a welder and a six pack and a day to do it.
The first thing i did was to take the seats out of the car and pull the carpet back over the rear seat. I ended up having the take the rear seat out of the car so to save some time i would just take it out along withe carpet. I wired in my amp that runs my speakers under the pass seat due to the lackof room under the drivers seat.
image_id: 19399
After removing the seats and carpet, i put my seat back in the car with the original brackets that i fabricated to install the aftermarket seat. All to make my marks on the unibody cross support the at the seats mount to.
image_id: 19402
I then cut two notches in the cross member, and cut out two flat plates out of 1/8 1.5 in flat plate. i fabricated three pieces to tie the cross member together to maintain the stength.
image_id: 19405
Then taped the two plates to the cross member, then installed the seat in the car for the second time. with the seat rails sitting in the notches sit in the seat and adjust the position to make it comfortable and take note that most aftermarket seats are wider so it will squeek one the door panel if moved over too far. when it is where you want it have a fraind mark where the bolt will be, if you don't have anyone close it gets interesting quick. then take the seat out again, then drill a hole in each plate and weld a nut on the backside.
image_id: 19407
now comes the welding of the fabricated pieces to the cross member, now remember to keep the heat on the thicker metal so it don't burn through.
image_id: 19418
Now that the front has been lowered time to go to the back. the first thing is to remove the tar like mat. the best way i have found is to put ice in a grocery bag and wait till it gets cold and it will chip right off.
image_id: 19401
The factory seat mounts will simply not work as they are too tall, i took my hammer and in two swings the mount was barly hagin on, this is not the best way to remove the driver side rear mount but after a few beers and it sounded like a good idea. for the right side rear mount i used the better saw's all idea and it worked much better. cut the mount as close to the tunnel as posible. In my case the tunnel was preventing my rail from setting all the way down which the hammer fixed.
image_id: 19423
now for the rear mounts i used the 1/8 steel strap and made a 90 degree bend for the right rear mount again with a nut welded to the bottom of it. I put a plate on the front of the right rear mount for added strength. the driver rear mount was made with the same idea but there has to be a notch in the corner for the wires the go to the back of the car.
image_id: 19421 image_id: 19424
after all the fabrication is done spray it with some red paint or primer. after the paint drys put it back together reverse of the disasembely. My seat came out 1.5 inches lower and it feels like a bigger car because i cant see the whole hood. in combination with this you might want to lower the stearing wheel by putting nuts between the colum and the mount bolts. there are more detailed pictures in my album.
image_id: 19434 image_id: 19436
I hope this helps for the people that rub there head on the headliner.
If you ain't First your last - Ricky Bobby
1990 swift GL Twincam swap
Hyundai trans swap- in progress
 Post subject: Re: DIY Seat Lowering
PostPosted: Tue Sep 21, 2010 9:55 am
Great write up. I bought a set of suzuki sport limited edition seats off a vitara that I would like to adapt and install, so this gives a good idea of how things look. Thanks!
PostPosted: Tue Sep 21, 2010 10:10 am
EngineWhisperer
:goodpost:
looking for:
PostPosted: Sat Sep 25, 2010 11:18 pm
There's more write up's to come. :D
PostPosted: Wed Oct 20, 2010 10:11 pm
excellent thread.
Paul
PostPosted: Thu Oct 21, 2010 1:02 pm
I am 6'3" and I fit. JUST barely. My head pushes on the headliner and sometimes "touches" the roof (I really an concerned but my neck if I were to hit a good bounce and not see it coming :-)
I would love to lower my seat but then my "knee angle" would be even worse than it is now :-) so I will live with the compromise.
you still have an INCH to the liner with a helmet on?? how tall are you?
PostPosted: Fri Oct 22, 2010 1:34 am
Well I am 5'11". the way i sit is with the seat at 90 degrees and on top of the wheel, everyone calls me crazy but that is how i drive.
PostPosted: Fri Oct 22, 2010 7:11 am
My distance to the wheel is limited by leg and arm length (I have to have the seat almost all the way back) but I too sit with the seat at 90' well as close as it will GET to 90' I wish it would sit up straighter but it won't (either it can't or I have bent it)
I CAN NOT drive "leaning back" it is excruciatingly uncomfortable to me. I need to be as straight up and vertical as possible.
I also have to be careful not to put my seat too far back. not only would I bend the rails if I did but there is a structural cross member in the roof and if the seat it back too far and I hit a bump..... lets just say ouch :-)
PostPosted: Sun Apr 03, 2016 3:42 am
Anyone has these images available...since I bought omp seats and I am nearly touching the roof. So I need to lower the seats. Thanks
Ask the experienced rather than the learned
PostPosted: Sun Apr 03, 2016 10:41 pm
It's a old thread but from the description you can picture what he did. Having that said maybe you can follow his instructions and post new pictures for newer members.
PostPosted: Thu Nov 17, 2016 10:42 pm
สถิติบาคาร่า
PostPosted: Wed Jan 25, 2017 10:20 am
Nice read. It would be helpful for a tall man like me.
