I own a 97 geo metro with the 1.3 8v engine. The block code is g13b and since it's an 8v that tells me it's the g13ba motor. Now I just bought a rebuild kit for a g13a not knowing that the g13a is a 77mm stroke when my motor has a 75.5mm stroke. Will that make a difference on how the rebuilt kit will work for my car as far as the main bearings, rod bearings, and thrust washers go? Also what about the gasket between the b block and the a block? Should I return the kit and order another? Here the link for the rebuilt kit
http://m.ebay.com/itm/281210115267?_mwBanner=1
