Does anyone have a dyno sheet showing these cams with stock pistons? I have them currently but have not installed them yet only because I am still a bit skeptical of loosing low end power. As I have heard a few people said they did not loose any low end power but if I could see a dyno sheet that would be great.
I have dyno sheets of my fairly stock motor and will be getting some done soon with my newly acquired chips from 'teeth'. After I install my set of cams I will run on the dyno again for some of you guys to benefit!
