It is currently Fri Nov 24, 2017 12:20 pm
Post new topic Reply to topic  [ 21 posts ]
 Post subject: Gti injectors size ?
PostPosted: Wed Feb 13, 2013 6:55 pm
Can anyone please tell me what size of injectors the 1989 swift gti came with and if i can upgrade those?
Hondas are like belly bottoms " Everybody have one"
 Post subject: Re: Gti injectors size ?
PostPosted: Wed Feb 13, 2013 9:21 pm
280cc or so if i'm not mistaken, if by upgrade you mean buy bigger ones, yes. Don't try to mod them yourself, you'll get the restrictor caps off and flow more, but your spray pattern/atomization of fuel will not be optimal.
AMSOIL Authorized Dealer, good prices, quality synthetic products. http://www.amsoil.com/StoreFront/defaul ... zo=5554512
Business startups for 50$ a year, unlimited revenue potential. Pm me or txt me 58one 30six-ten45.
PostPosted: Thu Feb 14, 2013 12:42 am
What i was trying to ask was what size are the stock ones and if i want to get bigger ones what size should get :?:
PostPosted: Thu Feb 14, 2013 8:24 am
This picture taken from Caaarlo's turbo project thread.
DSM's 390's are a good choice. Same plug type, relatively easy to get on ebay and all you need for up to about 1 bar turbo setup.
You can also use EVO 550's (I think they are too big to control).
For new injectors you could go with Injector Dynamics 750's or 1000's (large but the injectors are really well controlled down low).
I currently run ID1000's.
ImageET 13.138 at 120.2mph
PostPosted: Thu Feb 14, 2013 12:44 pm
Thanks fro the info guys i will get the dsm ones. Flying Grape when you said "1 bar turbo setup" what exactly you mean? Can i used this 390cc on the stock engine?
PostPosted: Thu Feb 14, 2013 1:29 pm
1 bar = 14.5 psi
PostPosted: Thu Feb 14, 2013 2:49 pm
Maybe in stupid but i dont get the bar thing :huh:
PostPosted: Thu Feb 14, 2013 3:08 pm
1 bar = earth's air pressure at sea level, approximately 14.5 psi.
Even though we call what we breath 0 psi, technically it's 14.5 psi. If we didn't have that we would erupt.... watch the original Total Recall and watch Arnold hit true 0 psi.......
Anyone who's been around children will tell you that they are in fact quite stupid. Many of them cannot even read.
PostPosted: Thu Feb 14, 2013 11:50 pm
Ok let see if i get this bar thing. If 1 bar equals 14.5psi the DSM 390cc injectors are 3 bars that its equals 43.5 psi :?:
PostPosted: Fri Feb 15, 2013 1:21 am
The dsm injectors are rated 390cc/min at 43psi fuel pressure.
Just an fyi... those are automatic turbo injectors. The manual turbos are 450cc
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Fri Feb 15, 2013 2:31 am
Bar is a unit of measure. Bar is to psi (pounds per sqare inch) as kilograms are to pounds. It's just another way to measure air pressure. 1 bar = 14.5 psi just like 1 kilo = 2.2lbs. There's also pascals and kilopascals. 1 bar = 100 kPa (kilopascals)
The injectors flow rates are rated at 3 bars of fuel pressure. The fuel pressure does not equal the injector flow. It means you need 43.5psi of fuel pressure to get the injectors to put out 390Cc's per minute.
1987 Chevrolet Sprint Turbo under construction
PostPosted: Fri Feb 15, 2013 6:08 am
What I mean is that a set of the DSM 390's gives enough flow for you to run a turboed g13b engine up to around 1 bar or 14-15psi of boost. I ran 11psi basic turbo setup using a t25 turbo for 125kW off standard rail pressure (36ish psi) and had plenty of head room. Yes there are also DSM 450's. Run the newer black top version which are a much better injector than the older blue tops. You can also find dead-time correction charts online to help calibrate your computer to get the injectors running spot on.
For NA to low boost I would go with 390's or black top 450's. With anything larger including e85 tunes I would just go straight to xspurt or Injector Dynamics 750 or 1000 cc injectors.
PostPosted: Fri Feb 15, 2013 3:05 pm
What mods have you done to your gti? We can't really tell you what size injectors you should use if we don't have an idea of the power you'll be making.
PostPosted: Fri Feb 15, 2013 9:55 pm
The only mods that i have on my GTI are Air intake and 255LPH High Performance Universal Fuel Pump from Ebay. With this DSM 390cc injectors do i need to get a fuel rail and a fuel pressure regulator? Im trying to get a bigger throttle body but im not sure wich one i need with this mods.
PostPosted: Fri Feb 15, 2013 11:40 pm
The stock injectors are plenty for just an intake. The stock throttle body is also plenty. I'd look into a set of cams and a chip first.
PostPosted: Sat Feb 16, 2013 12:18 am
Can you tell me what kind of cams i need and what chip? What do you thing about Sandro's chip? Do i use stock cam gear?
PostPosted: Sat Feb 16, 2013 12:11 pm
On injectors. Stick with standard injectors. You will be fine with these and if necessary can use an fpr if you start to run out of headroom.
Before you do anything though, if you are sticking to NA how much do you want to spend or do to the car?
Think about what you want for the car now and in the future. This is about making sure you are making modifications that are complimentary to future changes and hence making sure you are not wasting money on interim changes (assuming you are not making a couple of changes and leaving it at that....).
While people tend to do chips, TB, exhaust, cams etc first I think aftermarket ECU is a better starting point. You can therefore decide at various points to retune to take maximum advantage of setup and particular mods made and do things like different tunes for fuel types and offroad racing.
Yes it is a bigger starting outlay but you will save money in the long run and I think your tunes will better suit your car and engine.
PostPosted: Sat Feb 16, 2013 3:25 pm
:werd:
PostPosted: Sat Feb 16, 2013 6:29 pm
Well for know i just want to do some mods that dont have to spend too much money on them. Nothing crazy . I just want to have a reliable car have fun with it and in the process beat the crap out hondas hell yeah... :twisted:
PostPosted: Sat Feb 16, 2013 8:37 pm
you talk about hondas . Here in Houston i have a problem with silverado chevy truck's :o
PostPosted: Sat Feb 16, 2013 10:19 pm
Hondas are like belly bottoms "Everybody have one"
