I noticed the same when I disconnected the egr on my sprint when I got it years ago, so when I re-built the engine this last summer I capped off the hole on the intake with a piece of beer can between the valve and the manifold, and completely eliminated the rest of the associated hardware, and smashed flat and folded over the stub of pipe sticking out of the exhaust. I live in the middle of nowhere in NV, so meeting emissions regulations is not a problem for me.
From the explanation of egr systems that I have found, it makes complete sense that if it is working properly it will rob power, as its purpose is to essentially pad the intake charge with unuseable gasses, effectively lowering the volumetric efficiency of the engine with the result of cleaner emissions.
_________________ 87 Chevy Sprint 1.0L Carbureted. 3-Tech 226/395 Cam - Weber 32/36DGEV The car I learned to drive a manual transmission and took my driving test in. Was left as dead in the desert for 10 years. Resurrected and modified to be my daily driver and fun little toy. Ugly everywhere but under the hood!
