Mmmmm beer examples. A true engineer. Some suspension engineers over at Whiteline in Australia put together an excellent general FAQ, no beer talk, but still lots to read.<br><br><!--EZCODE AUTOLINK START--><a href="http://www.whiteline.com.au/faqsprings.htm">www.whiteline.com.au/faqsprings.htm</a><!--EZCODE AUTOLINK END--><br><br>Whitelines springs for GTi are meant for your mild racer/auto-xer. They are not springs for 'looks'. 150 lbs/in front and in the rear 450 lbs/in. This may seem mismatched but with a spring-to-wheel motion ratio of 1:2.5, it becomes 180in/lb at the wheel. If you place the spring over shock it becomes 1:1. i.e. Coil-overs. Coil-overs you would then want the 180 lbs/in spring, to match your 150in/lb spring in the front.<br><br>A full coil-over set up on a GTi requires modifications to the rear of your precious GTi that you may or may not want to do. Front coil-overs will work, however if you want the rears, you must take a 'sawzall' and remove a good portion of the outer skin of the rear shock tower. If you are serious into racing more like Liam and have a dedicated car, you may want to go with coil-overs jsut for the adjustability. Height adjustability, flexibility to swap springs on different tracks, etc.. They arelikley to be noisier, and have a lower life cycle than street springs. There are some serious race Swifts out there like Jason Steinhards still using stock suspension in the rear well enough. <br><br><!--EZCODE AUTOLINK START--><a href="http://www.speedoptions.com/features/cars.php?carID=84">www.speedoptions.com/feat...p?carID=84</a><!--EZCODE AUTOLINK END--><br><br>A message in a discussion with ESRworks Racing a long time ago. They have extensively researched and worked on the GTi chassis many different spring rates, playing around with removing front sway bar together, even removing the rear sway bar in favour of a custom rear design. <br><br>From what I gather for your average Swift racer looking for coil-overs using relative confines of stock suspension set-up. Go with a 10" long 2.5" ID spring. Around 350 front and 400-500rears. As mentioned, this will of course vary according to your own needs. ESR used 8" springs, and huge spring rates<br><br>-------------<br>From ESRworks...<br>Typical set ups are GIANT sway bars and like 500 to 1000 pound springs. I started with 350 front- 300 rear and rear swaybar and no front swaybar. I removed the rear swaybar and put inthe limiter i told you about which works awesome with such high HP i run. You might want to use 400-500 rears<br>--------------<br>Back to my mumble...<br><br>The big reason for coil-overs is just adjustability, and expirementing to find the right combination of spring rates could likely be a costly proposition and set up. What end result you are after, is up to you. But you now should definetely have some things to consider. <br><br>As for basic set-up for your average racer on a budget? Start with the simple things like Liam pointed out. Polyeurethane bushings, Adjsutable shocks, performance springs, rear sway bar, R compound tires if you race, and perhaps a little bracing (chassis flex isn't always altogether bad). If you are racing and want to stay in a lower class, you will have to find out what the rules are and figure out how you want to be competetive. For instance, according to WCMA classifications and ruling, The above mods would put you in something called Super Stock (S, SS, SP, M). Now taking the next step and having camber adjustments are an excellent idea, but the Swift does not come with the ability to adjust 'camber' stock and if you add them the preparation points required will just move your GTi up into the next class of Street Prepared. A much more competetive class, usually with exerpienced people with cars built to max out the points in the SP class (turbocharged, or perhaps maxed out with trick suspensions). Your car with the above mods would just be entering hte SP class and bottom of the points scale. Hard to compete. As for biggest improvement in lap times with the above limited mods, something like the adjustable Konis shocks I have seen decrease lap times much more than either a sway-bar or the springs. Hence adding to what Liam mentioned about shocks being so important. Certain springs will give better response and turn in than others available out there. My H&Rs tested against Intrax win in that merit. I'm sure there are other good options to chose from as well. The larger rear sway bar as a bonus is excellent for helping keep the front wheels planted around corners. Oh, of course an LSD is an excellent help in keeping one stupid tire from spinning coming out of the corner. <br><br>In essence decide what you are building. Decide where/ what class you want to compete in. If you want to compete at all. Decide if coil-overs are worth it for what you will be doing. And play around for how you like it. The above things are all proven to work wonderfully on the GTi. <br><br><br> <p>-Kyle Jones <!--EZCODE LINK START--><a href="http://www.angelfire.com/de/ksj/myswift.html"><br><!--EZCODE BOLD START--><strong> Junk-Yard Turbo set-up, formerly NOS-fed, constantly evolving 1989 Suzuki Swift GTi</strong><!--EZCODE BOLD END--><br></a><!--EZCODE LINK END--><br></p><i></i>
